Help My PC wont boot
Go to solution Solved by BrinkGG,
i have built my pc AMD 6300 8GB ram (2x4) r9 380 550w evga psu and a msi 970 gaming mobo and when i turn on the pc i just get a blank screen and it wont go to the bios or anything what has happend and how can i fix this
Make sure your monitor is displaying the correct port from your computer (HDMI if thats the cable and so on), if not, try a dry boot: single stick of RAM in the closest slot to the CPU, GPU in the PCI-e slot closest to the CPU, NO HARD DRIVES OR SSDs, and the power supply plugged into only the motherboard and graphics card. And see if that gets you to the BIOS. If that works, shut the system all the way down and add hardware one piece at a time to see if you can find what piece is the problem.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/515880-help-my-pc-wont-boot/#findComment-6861131
