Operating System
Go to solution Solved by Clear17Mud,
OK I have to re write everything, because it won't let me edit that post... Get the win 10 installer. Then install it on your PC with 64 bit. When it asks for a key click skip then once its installed it willbtell you that it needs to be activated so click auto activate(it requires internet) it should work because it saves the mb vin number or what ever, and I don't even get why they have 32 bit windows 10...
https://linustechtips.com/topic/515649-operating-system/#findComment-6858441
