Instant problem with connectors
Solved by W-L,
My power led has three holes while the instructions say else wise please help pictures below
The Front IO isn't fully standardized with the placement of the pins since some have the PW LED spaced out in the middle with an empty slot. It doesn't make a difference if you leave it unplugged, if you want it you can re-pin it so the pins are right beside each other in the connector or use an adapter which some provide.
