Hi,
     I've had some issues with my pastel coolant and to try and limit my issues I've decided to move onto rigid tubing. The only issue i'm having (right after Christmas) is finding fittings for a reasonable price as I need 20 in total.
Also I not sure if my dual loops will be too "busy" to fully utilise/fit it all in.
Is there anyone that can offer some advice please to swap my sig/project loops to rigid?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/515309-first-time-using-acryllic-tubing/
Hey, PETG which I tagged in the title but never mentioned in my post lol, the tubing is cheap, prob £20 in total and around £30 for a cutting/bending kit. But then its like £5 + per fitting
Ryzen Ram Guide
