Help please with Graphics Cards capabilities?
Sorry, wasn't sure at all where to post this but of all components I suppose my question is more related to Graphics Cards.
I think I am going to soon buy this (http://www.scan.co.uk/3xs/configurator/overclocked-custom-gaming-pc-uk-nvidia-sli-vengeancesli).
I currently have a BenQ G2400W monitor. I am yet undecided as to what monitor I will upgrade to, but it will probably be one of the following four:
So, I will buy one of the above, then just have my BenQ as a side monitor for now for low demanding background tasks / multitasking. I will eventually want to buy a second (and maybe third) monitor (which I think will be the same as the first monitor) to replace the BenQ.
I guess the question is three part:
  • Will the system be able to run games at a good level when using either of those above monitors?
  • Will the system be able to run games at a good level when using two of either of those above monitors further down the line?
  • Will the system be able to run games at a good level when using three of either of those above monitors further down the line?
In terms of games played, it will be the likes of Rainbow Six Siege, Battlefield 4, Counter Strike: Global Offensive and of course Football Manager 2016!
Any help much appreciated, if anything is unclear please let me know!
https://linustechtips.com/topic/514424-help-please-with-graphics-cards-capabilities/
two 980ti will do a pretty decent job @4k/UHD so nothing to worry about
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
2xGTX 980ti will handle 3 1440 monitors.
Not at high+ setting, especially if you want the frame rate to be close to the refresh rate. Guess that depends on the games also
£899.98 for this Card is a Joke, right?
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
You guys know that that's the price for 2 cards right? Or is that still expensive?
You sure about that? Dont see a Number. For 2 Cards it would be ok.
