Two-Way SLI
Go to solution Solved by z97,
Yes however they may not run as well as the top two.
So my SLI bridge won't reach between my two 780Ti's which I have in the top 2 slots. Can I move the two GPU's to the bottom 2 slots as they are closer together?
That is slot 2&3 instead of 1&2 which won't reach.
Quick response would be great.
Also does the SLI bridge go on the left GPU sticky outy thing, or the right one?
https://linustechtips.com/topic/514020-two-way-sli/
CPU: I7 5960X @4612 MHZ/1.325Vcore | Cooler: Full custom loop | Mobo: Asus X-99A | GPU: 2 EVGA 980 TI Classifieds | RAM: G.Skill Trident Z 32 GBs 3200 MHZ | Storage: Samsung SM951 512 GB M.2 Drive, Mushkin Eco2 512 GB SSD, Muskin Chronos 480 GB SSD | PSU: Corsair HX 1000i | Case: Fractal define R5 | Monitor: LG 34UC87M-B
https://linustechtips.com/topic/514020-two-way-sli/#findComment-6841596
You can buy long SLI bridges.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/514020-two-way-sli/#findComment-6841785
