Uhm why??? Does it not show up? do you not have a cable? did you try the motherboard onboard graphics?
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/512413-no-display-input/#findComment-6826832
Are the fans on the GPU plugged in? (Also some specifications of your computer would be nice)
https://linustechtips.com/topic/512413-no-display-input/#findComment-6826861
Sorry, I meant are the fans on the GPU spinning*
https://linustechtips.com/topic/512413-no-display-input/#findComment-6826869
yes
fx 4300
msi 970-43
kingston hyperx fury 8gb 1866
gigabyte gtx 960
Try a different cable?
https://linustechtips.com/topic/512413-no-display-input/#findComment-6826889
