Hi everyone, i just got a quick question about this as im a bit worried,
when i am playing a game, lets say civilization beyond earth, i get "lines" across my screen. nothing super bad, i can still play and game normally but its like interference, can it be a bad cable? or bad screen? or maybe frame rate is too high?
its hard to take a picture on it how it looks but. is it dangerous? im currently using a vga-dvi adapter (for 2 days as emergency)
thanks!  ^_^  ^_^  ^_^
┏(◑̃.◑̃)┛ Totally Not Dangerous ┏(◐̃.◐̃)┛
i7 4790K / 16GB RAM \ 250GB SSD
https://linustechtips.com/topic/511198-gtx-970-maybe-problem/
Check if temps are okay, try underclocking the card a bit (memory especially) and see if that yields any benefit.
Also play around with the cable a bit.
Also that adapter might be causing you an issue, IDK.
Sig under construction.
https://linustechtips.com/topic/511198-gtx-970-maybe-problem/#findComment-6814023
thanks!  ^_^  ^_^  ^_^
You play the civ games? Do you have civ5? But more on the matter, does it happen in any other game? If not, we can assuming it's the game itself, not the gpu.
https://linustechtips.com/topic/511198-gtx-970-maybe-problem/#findComment-6814024
Is it screen tearing or something else?
https://linustechtips.com/topic/511198-gtx-970-maybe-problem/#findComment-6814029
the temps are not over 65c and the memory clock speed at stock, all at stock but its factory OC so maybe i should under clock it? how do i do that? ...msi afterburner...?  it also happens when i use a normal cable
  it happens in every game... yes i got civ 5...
don't know how that look... maybe?  :o its 60fps on a 60hz monitor...
https://linustechtips.com/topic/511198-gtx-970-maybe-problem/#findComment-6814052
Test and see if it happens in any other games, monitor your temps, reset any overclocking, update your drivers, and if it still persists in multiple games, then either your monitor or GPU is dying.
Civ5 best game nukedbyghandi/10
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/511198-gtx-970-maybe-problem/#findComment-6814054
NO.....   i got it yesterday after the last one was bad...  :angry: i will try to under clock it... to around what? i dont know what to do  :wacko:
totally
https://linustechtips.com/topic/511198-gtx-970-maybe-problem/#findComment-6814077
totally
Do you have another monitor you could try it on? If so, you could find out for certain if its the GPU or monitor's fault
https://linustechtips.com/topic/511198-gtx-970-maybe-problem/#findComment-6814098
not a pc monitor no... but a TV? or that's even worse?  :unsure:
https://linustechtips.com/topic/511198-gtx-970-maybe-problem/#findComment-6814106
A TV would probably work. A friend of mine only had a TV in his house, so he has both his xbox 360 and PC on it.
https://linustechtips.com/topic/511198-gtx-970-maybe-problem/#findComment-6814126
I will try under clocking first and later if its still same i will try the tv...  :unsure:
https://linustechtips.com/topic/511198-gtx-970-maybe-problem/#findComment-6814134
You guys wanna play civ 5 sometime?
https://linustechtips.com/topic/511198-gtx-970-maybe-problem/#findComment-6814137
Something like this,
or this
https://linustechtips.com/topic/511198-gtx-970-maybe-problem/#findComment-6814139
I did try with the TV, it worked better, i guess it's just the cable/adapter!
 thanks all for trying to help out! little embarrassing it was "just" that, but i had a defect 970 before (1 week ago) and yeah...worried  :blink:
https://linustechtips.com/topic/511198-gtx-970-maybe-problem/#findComment-6815211
