What's your budget and what form factor is your motherboard?
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/51088-new-case-need-help/#findComment-682050
The Carbide 300R Windowed? I'm not really sure what you mean by "smaller".
CoolerMaster Storm Scout 2 Black - Intel Core i5-4570 - CoolerMaster Hyper TX3 Evo - Sapphire Radeon HD7950 - Corsair Vengeance Pro 8GB - ASRock Fatal1ty H87 Performance - Seagate Baracuda 1TB HDD - Sandisk SSD Plus 240GB - Seasonic G-550 - BenQ GW2255 21.5" LED Monitor
2016 MacBook Pro 13" - Google Pixel
https://linustechtips.com/topic/51088-new-case-need-help/#findComment-682074
Like a small, but awesome looking case? With a window, and great cable management. If possible ^^
Budget is about £70. Mobo is an ATX. Specs are in my sig
It also needs to be able to fit my LCD fan controller too. Fan controller is a v12xt.
Update coming soon.......... ;)
https://linustechtips.com/topic/51088-new-case-need-help/#findComment-682081
You're not really going to get anything smaller with that motherboard size, you would have to go down to matx or itx if you want a smaller case.
https://linustechtips.com/topic/51088-new-case-need-help/#findComment-682101
Darn :( well what case could I go for? With a Window and great cable management? :) ( on the cheap side)
Fractal design define R4 is pretty good, here's one with a side panel:
http://www.amazon.com/gp/product/B008HD3E82/ref=s9_simh_gw_p147_d0_i5?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=1K4H629KBRS929AZCKRH&pf_rd_t=101&pf_rd_p=1389517282&pf_rd_i=507846
It's about the same size as the one you have now, but it looks a lot cleaner and has a side panel. Cable management is pretty similar to what you have now.
https://linustechtips.com/topic/51088-new-case-need-help/#findComment-682129
The 400R you have is great! Why do you want to replace it? You can mod a window I think.
https://linustechtips.com/topic/51088-new-case-need-help/#findComment-682133
Modding will probably be cheaper but more work. If you will mod you will have to get familiar with all the tools you will need and how it should be done.
https://linustechtips.com/topic/51088-new-case-need-help/#findComment-682225
i dont think you can go much smaller with a full sized atx mobo
Specs cpu:  i7 4770k  mobo: z87-pro RAM: Corsair vengeance 8GB GPU: EVGA GTX 770 HDD: WD blue 1TB psu: TX750M case: 550D cooling: H100i monitor: Dell U2410/Samsung sa350
I <3 senheiser, ASUS, Corsair, Intel
https://linustechtips.com/topic/51088-new-case-need-help/#findComment-682229
I have a Thermaltake Chaser A31 in thunder blue and love it.
you can also look at the Corsair carbide 300r for compact rig, or C70, Fractial Design R4.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811124155
^^^ if you like red and black check this one out..
got to love Asus components
https://linustechtips.com/topic/51088-new-case-need-help/#findComment-687144
