A friend purchased a power supply unit [Corsair CX 750M] from a website based in the United States. It comes with a US power cord. Can I simply use a spare UK power cord to use it here or would I need to purchase a voltage converter or something?
You should be able to find a power cord that plugs into a UK socket that naively plugs into the CX. The connection to the PSU directly is universal so it should work if you find a different cable.
https://linustechtips.com/topic/510849-power-supply-help/#findComment-6810272
