So i made a post yesterday about my pc didn't show up on the screen
And i have started from scratch taking off the motherboard, taking out all the parts and stuff
And i put them all in again
All the lights are on and all the fans are spinning but nothing shows up on the screen...
What should i do!
PC Specs
Gpu: asus geforce gtx 970 strix
Cpu: i5-4690k
Motherboard: Asus z97-E
Psu: Evga supernova g2 550w
SSD: sasung evo 250gb
Case: CM Master Case 5
https://linustechtips.com/topic/507763-need-help/
Try to use a VGA cable and connect it to your motherboard to see if the graphic card is the problem
If it shows an image after this, you could try downloading drivers and see if that helps
Long live Stalin, he loves you; sing these words, or you know what he’ll do!
https://linustechtips.com/topic/507763-need-help/#findComment-6775525
do i need a optical drive to download the drivers?
No, just connect your VGA cable to the motherboard, and download the drivers online
http://www.nvidia.com/download/index.aspx
https://linustechtips.com/topic/507763-need-help/#findComment-6775720
