Unknown Device Problem
Go to solution Solved by Grrizz,
That's weird I don't see any reason for it to be "gone"... is there any specific way to download the driver?  ^_^
'9 Series Chipset Family Thermal Controller' I think.
I would check you motherboards website first alternatively go to Intels website and look up drivers for your chipset.
Edit: Or try this https://downloadcenter.intel.com/
So yeah =/
I think it's the GPU or something as it has to do with PCI but windows won't really let me install so how do I fix it? I tried to search on some database with the numbers but I don't know how.
Please help?  ^_^
┏(◑̃.◑̃)┛ Totally Not Dangerous ┏(◐̃.◐̃)┛
i7 4790K / 16GB RAM \ 250GB SSD
https://linustechtips.com/topic/506247-unknown-device-problem/
Looks like its a Intel chipset driver.
https://linustechtips.com/topic/506247-unknown-device-problem/#findComment-6757353
https://linustechtips.com/topic/506247-unknown-device-problem/#findComment-6757364
Thanks! It worked  ^_^
https://linustechtips.com/topic/506247-unknown-device-problem/#findComment-6757433
