So after talking to my bestie about Visual Studio taking ages to update to Update 1, I thought "I should make my build Visual Studio themed" with like purple LED's etc because I heart Visual Studio (C# ftw). I'm going to use the PC for programming (obviously), Gaming at medium and up settings at 1080p, and school work. What do you guys think I should do? My budget is $800 Canadian. Thanks
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
https://linustechtips.com/topic/506179-visual-studio-themed-build/
I'll be looking as well but Visual Studio doesn't want to update -.-
AXIOM
Wow, there's no money for a GPU :P, might just have to get the Z97 board with a 4460. I could probably custom paint the CPU cooler fan, then maybe get a round visual studio sticker. Maybe if I raise my budget to $900, I could actually get a decent build, I'll keep looking
AXIOM
Might spray paint the heat sinks purple, that would look pretty cool, but would that void the warranty?
AXIOM
i'll see what i can dig up, i'm probably gonna pick black/white parts, and leave some room for purple LEDs, the purple light will make all the white show up purple.
Why white though?
Visual Studio really isn't white-themed, at least in the few latest versions.
Why white though?
i'd go with parts with white details because OP mentioned purple, and purple components being non-existant, white is the easiest color to turn purple with LEDs.
Ah , I get it now.
The version I have is white with purple accents, even the logo is purple, you must have dark mode on or something
AXIOM
And I meant paint the mobo heat sinks white
AXIOM
