Buy my yoga 2 pro!  http://linustechtips.com/main/classifieds/item/2711-lenovo-yoga-2-pro-i7-4510u-8gb-ram-4k-btc-accepted/
[spoiler=Trumps Wall
]AMD FX 8320 OC@ 4.4 GHZ GPUamd sapphire 7950RAM: 12GB CORSAIR XMS3 Psu: Corsair cx 500m CASE: Corsair 800d MOBO: Asrock 970 extreme 3 r2 Storage: 256GB mx100 SSD, 1TB WD Blue,1tb Seagate Barracuda in Raid 0, 750GB Seagate Baracude. Os Windows 7
CPU: AMD A-10 5800k RAM: 4GB DDR3 Storage:Random drives Mobo:msi SomthingCase: good question
https://linustechtips.com/topic/506024-will-his-adapter-work/
nope
thats for mac, which ports thing strangely
youll need an active adapter, sorry
displayport adapts cheaply to all other standards, at my parents' company they have all DP graphics cards in the office computers with adapters like these to vga.
https://linustechtips.com/topic/506024-will-his-adapter-work/#findComment-6754266
no, you'll need a digital to analogue converter.
Intel i5-6600K@4.2GHz, 16GB Crucial DDR4-2133, Gigabyte Z170X-UD3, Be quiet shadow rock slim, Sapphire RX 480 Nitro+ OC, Fractal design Integra M 550W, NZXT S340, Sandisk X110 128GB, WD black 750GB, Seagate momentus 160GB, HGST 160GB
https://linustechtips.com/topic/506024-will-his-adapter-work/#findComment-6754271
but... vga...
yes, it should work, the adapter looks dodgy as all hell tho...
its for a projector, do you have a recommendation?
https://linustechtips.com/topic/506024-will-his-adapter-work/#findComment-6754291
the problem with the "for mac" stuff, is that companies like to slap that on products with a white casing to make iSheep think its superior to other products, whine in a lot of cases its not even on par with cheap garbage.
https://linustechtips.com/topic/506024-will-his-adapter-work/#findComment-6754317
