Hey! i am getting a pc in February for gaming and rendering. i have already bought some parts such as the graphics card and CPU.
The pc will run games such as just cause 3, star wars battlefront and similar games to that! I was also looking for 2 monitors to be paired with it but i have no idea what 2 to buy! help please?
 LInk: http://uk.pcpartpicker.com/p/C3rPwP
MY RIG
I5 6600k
16gb Corsair vengeance 2666mhz
MSI Gaming X 1070
WD blue 2tb
samsung 850 evo 250gb
EVGA supernova G2 650w
https://linustechtips.com/topic/505428-gaming-rendering-pc-help/
You should get the R9 390 because it performs better at most games and is more future proof unless you are a die hard Nvidia fan. What resolution do you want the monitors to be?
https://linustechtips.com/topic/505428-gaming-rendering-pc-help/#findComment-6746121
Get a BeQuiet! Pure Rock CPU cooler.
Get a EVGA GS or G2 PSU and you should be fien and also the 950 PRo is a bit of a jump I don't think it is needed and a 850 Evo would be perfectly fine.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/505428-gaming-rendering-pc-help/#findComment-6746134
1080p should be fine, i also have the 970 for the cuda cores for rendering :P
MY RIG
I5 6600k
MSI Gaming X 1070
WD blue 2tb
https://linustechtips.com/topic/505428-gaming-rendering-pc-help/#findComment-6746137
I need major speed xD
MY RIG
I5 6600k
MSI Gaming X 1070
WD blue 2tb
https://linustechtips.com/topic/505428-gaming-rendering-pc-help/#findComment-6746146
For what? You can get a 850Evo M.2 cheaper and the speed difference is not much. Though keep my other suggestions in mind, especially the BeQuiet! Pure Rock
https://linustechtips.com/topic/505428-gaming-rendering-pc-help/#findComment-6747131
