Hello,
I have a problem here.
I got a new i5 4460 and a new motherboard.
Once I installed it into my existing system and booted it, every component started but I did not get any image on my screen. Only when I completely removed my graphics card and used the onboard graphics everything worked fine.
When I put in an other card into that system everything worked fine too.
So I thought my graphics card had broke down, yet when I put the card onto an other motherboard and other cpu but with all the components used before, everything worked fine too.
So in theory all the parts work.
Maybe someone of you could hekp me with this.
Thank you.
https://linustechtips.com/topic/504809-system-does-not-post/
Is the GPU pushed in properly? Don't be afraid to use force. Also, I'm not sure if this can even happen but is it possible the MoBo is incompatible with GPU?
Build: i5-4460 | GT 720 | Logitech G710+ Keyboard | Corsair M65 Mouse | Dell e2314h Monitor | Windows 10
Generic Dell: Mobo, 8gb RAM, 430w PSU, 1TB Storage, XPS 8700 Case
https://linustechtips.com/topic/504809-system-does-not-post/#findComment-6738130
Are your ram sticks completely pushed in?
Also welcome to the LTT Forums, you will never go back.....
CPU AMD Ryzen 5 3600x | GPU GIGABYTE GTX 1070ti WINDFORCE | MOBO ASUS Prime X570-P | MEMORY XPG Spectrix 2x8GB 3200MHz  | PSU OCZ Zx 850W | CASE NZXT H440
https://linustechtips.com/topic/504809-system-does-not-post/#findComment-6738131
GPU is pushed in, just tested it again. I am using an ASUS H81-Gamer motherboard and a Gigabyte G1 GTX 960. I tried finding anything about incompatibility, but haven't found anything.
https://linustechtips.com/topic/504809-system-does-not-post/#findComment-6738323
