Cheap power supply replacement?
Go to solution Solved by Guest,
a little on the expensive end.
expecting some cheapo one that "works" for around 45€?
Alright, here is a the cheapest unit from a brand I recommend, as wel as effiency I require for my customers:
http://www.cclonline.com/product/178981/SST-ST60F-ESB/Power-Supplies/Silverstone-Strider-Essential-Bronze-600W-SST-ST60F-ESB-/PSU0816/?siteID=8BacdVP0GFs-0lYlI6X2gcnrRpdOygFgEw
Hi guys, a friend of mine in Netherlands has probably smashed his power supply.
Power button-> All fans spin, no post, nothing. Black screen.
Temps on CPU+GPU+RAM+MOBO were all fine.
 Dno if pc was on a carpet so power supply got strangled maybe, or just old age.
All parts on stock
CPU: i5-2500
MSI 560 Ti Twin Frozr.
8GB DDR3
1 tb hard drive.
What kind of cheap power supply could we get as replacement?
How much wattage would a system like this need? previous one was 600W he thinks.
AMD Ryzen R9 5900X  | Arctic Liquid Freezer II 360  |  GIGABYTE X570S AERO G  |  2x32GB G'skill TridentZ 4000MHz  | MSI RX 6900 XT Gaming Z Trio 16GB Dark Base Pro 900 (Orange)  | TOSHIBA 4TB 3.5" Drive - Game Drive | KINGSTON SNVS1000G 1TB M.2 NVME SSD - Boot Drive | FSP Hydro PTM PRO 1000W |
Living Room PC: AMD Ryzen 2400G | MSI RX VEGA 56 8GB AERO | 2x8 GB Crucial Ballistix 2400MHz | Intenso 250GB SSD | Seagate 500 GB HDD | Node 202 + 850W PSU |
https://linustechtips.com/topic/504764-cheap-power-supply-replacement/
Can you link us to where you're shopping?
pricerunner probably :D
Here is a great 600 Watt PSU that is 80 Bronze certified:
http://eu.evga.com/Products/Product.aspx?pn=100-B1-0600-KR
