Is 650W enough watts for this build with overclocking, or should I buy a PSU with more watts?
I want a good reputable PSU which is fully modular too.
Power Supply: SeaSonic 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($93.99 @ SuperBiiz)
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($698.89 @ OutletPC)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($123.99 @ SuperBiiz)
Thermal Compound: Arctic Cooling MX4 4g Thermal Paste  ($5.95 @ SuperBiiz)
Motherboard: Asus MAXIMUS VIII HERO ATX LGA1151 Motherboard  ($219.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($77.88 @ OutletPC)
Video Card: Asus GeForce GTX 980 Ti 6GB STRIX Video Card  ($654.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Pro Full (32/64-bit)  ($199.99 @ B&H)
Monitor: Asus VG248QE 144Hz 24.0" Monitor  ($259.99 @ B&H)
Keyboard: Corsair K70 RGB Wired Gaming Keyboard  ($169.95 @ Amazon)
Mouse: Logitech G502 Wired Optical Mouse  ($56.99 @ Amazon)
Total: $2922.47
Generated by PCPartPicker 2015-12-13 12:21 EST-0500
https://linustechtips.com/topic/504662-help-choosing-a-psu/
the one selected is excellent quality
https://linustechtips.com/topic/504662-help-choosing-a-psu/#findComment-6736390
650W is enough and you picked a great PSU!
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/504662-help-choosing-a-psu/#findComment-6736400
Yes, but dont get Windows 10 full and this is the same price but better
I had one other person recommend that exact same PSU, but many people told me to stick with Seasonic.
Okay, I've had a few people recommend to go with 750W so I'm just not 100% if 650W is good for when I overclock.
Are there any fully modular Seasonics you would recommend?
I've heard only good things about Seasonic, I'm just not sure if when I overlock if it's a better idea to have 750W?
Also, any recomendations for a fully modular Seasonic?
https://linustechtips.com/topic/504662-help-choosing-a-psu/#findComment-6736463
SeaSonic X-series 650W is all you will ever need
https://linustechtips.com/topic/504662-help-choosing-a-psu/#findComment-6736473
SeaSonic makes very good PSUs but SuperFlower (makers of the EVGA G2) are on par with them.
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/504662-help-choosing-a-psu/#findComment-6736568
Will the fans be loud and spinning a lot with the 650W?
nope - SeaSonic above the M12II are whisper-quiet
https://linustechtips.com/topic/504662-help-choosing-a-psu/#findComment-6736657
I couldn't find the SeaSonic X Series 650W 80+ Gold on pcpartpicker.com
Just to confirm, is this the correct one? http://www.newegg.com/Product/Product.aspx?Item=N82E16817151088
exactly
https://linustechtips.com/topic/504662-help-choosing-a-psu/#findComment-6736684
