(Processor) Sony Vegas help!
Solved by i_build_nanosuits,
H1Z1 is built on the same engine as arma3 and those games run aweful especially on AMD CPU's because they max out one CPU core and AMD cores are weak and slow...so you should go with the i5-4460 on a cheap H97 motherboard...performance in rendering is still very similar to the FX and the editing will be smoother because the intel chip has much faster cores, it's also a lot more energy efficient and come on a more modern platform with better features.yeah ima do a lil gaming on pc like h1z1 or rocket league but big titles i play on xbox one like black ops 3 and so on
I think you should get
- i5-4460
- H97 board
- 16GB DDR3
- R9 380 4GB
Use the boxed heatsink for the i5 it's perfectly adequate for that little chip.
