- I have an SSD as primary drive with Windows 8.1 on it.
- I have a HyperX (Kingston) 16gb pendrive USB.
I made a bootable Win7 iso using Microsoft USB tool on the pendrive.
- I have an 1TB Seagate 7200RPM 64MB SSHD that I bought today.
- I have Gigabyte Z97X Gaming 7 mobo
- I set boot order in BIOS to make the pendrive primary.
Windows7 setup loads just fine but after I create partition on the "Disk 1: Unallocated Space" (the SSHD) and I click next it says "Setup was unable to create a new system partition....check log".
I also noticed that after creating the partition it does not create a system reserve (100mb) partition as it usually does.
I tried the following (none worked):
- Plugged out SSD
- Formatted new partition
- Tried installing on unallocated space
#I tried booting from another hard drive (I put boot files on the hard drive) and it worked, I installed Windows 7 but after I pulled out that boot hard drive, it said no OS found so I'm guessing there's something to do with the USB?
https://linustechtips.com/topic/502836-help-pls/
Snip
Your problem is Windows 7.
Go into your UEFI and find the CSM or Compatibility Support Module. It will be disabled, enable it then try the install again.
Let me know if it doesn't work and what exactly it says.
Main Rig:-
Server:-
https://linustechtips.com/topic/502836-help-pls/#findComment-6713943
Ok there are two tabs I found:
- CSM Support
It has two options:
Always (it's currently set as default)
Never
- Windows 8 (or similar I forgot, lol)
If I click on it gives 3 possiblities:
Other OS
Windows 8
Windows 8 WHQL
https://linustechtips.com/topic/502836-help-pls/#findComment-6714022
- CSM Support
It has two options:
Never
Other OS
Windows 8
Windows 8 WHQL
Hmm, that's weird. Fyi the second set of options you listed do nothing without the CSM set to Never first but the CSM is set to the correct setting for Windows 7.
Please unplug all other HDDs from the board entirely and just leave the drive your installing on to plugged in on it's own then try again. It sounds like a weird suggestions but in my experience most issues when installing Windows are caused by having multiple drives plugged in during setup.
Main Rig:-
Server:-
https://linustechtips.com/topic/502836-help-pls/#findComment-6714079
Already tried that...didn't work.
https://linustechtips.com/topic/502836-help-pls/#findComment-6714090
Ok then.
Next thing to try is bring up the boot menu (usually F11 during post) and look through the boot list.
Is the pendrive listed twice? One will have (UEFI) next to it. If so then select the one that DOESN'T say (UEFI) and try again.
Main Rig:-
Server:-
https://linustechtips.com/topic/502836-help-pls/#findComment-6714122
Ok then.
I checked the pheripherials and it has:
USB Storage Devices:
Kingston .... (my pendrive with NO uefi next to it)
When I click it (my pendrive's name), it shows these options:
Auto
Floppy
Forced FDD
Hard Disk
CR-ROM
https://linustechtips.com/topic/502836-help-pls/#findComment-6714210
