I can only hear from one ear on my HD 449, I know it seems to be the jack of them compared to my 598
As the middle of the jack has slightly come out, is there anyway of fixing it so I can hear through both again.
P. S it works if I apply a slight pressure to one side when plugged in.
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/502664-headphone-issues/
Feel confident taking it apart? Sounds like there's a lose connection to whichever side you are applying pressure to. I cant find a tear down guide online. But if possible Id try taking the casing off the ear cup and looking for a broken solder joint or something along those lines. If it makes you feel better there really isn't much to speakers/headphones wiring wise. If you take it apart, theres wont be many connections to look at. If you can get it to a state where the wiring is exposed. Plug it in and press/jiggle the wires till you find one that makes the speaker start working and try to repair where ever the bad connection is.
edit: By middle of the jack has come out, you mean on the 3.5mm connector? Could you elaborate?
https://linustechtips.com/topic/502664-headphone-issues/#findComment-6711644
