Mouse Help?
Go to solution Solved by Kira0172,
Xh9PSQu.jpg?1
Hey I have been trying to research and look into mice for a while now but am still having a lot of trouble finding the right one.
The first issue is that I have very large hands (9" from palm to middle finger tip) so finding a mouse becomes more an issue because of this.
I do not know a lot about the sensors within mice and what's good and what is not in terms of acceleration and tracking and that is partially why I came here with this question is hopefully to get more educated opinions than my own.
From what I have been looking into I have gained an interest in the Logitech g600 (tried it at a local computer store seems to fit my hand pretty good) and the Logitech g9x. I play many types of games such as cube world, minecraft, LoL, planetside 2, MMO's, and the occasional FPS and Role Playing games. Let me know what you think of these and if they are not the best choices feel free to tell me why and leave a recommendation. Thanks, Wenzel.
https://linustechtips.com/topic/50240-mouse-help/
What's your budget? Something from the R.A.T series might suite your needs, since you can pretty much customize it to fit any hand, many people say negative things about them, but I've been using a R.A.T. 9 for a year and a half and absolutely love it!
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/50240-mouse-help/#findComment-670056
G9x, G600 would be a good choice
That was fast! (your profile pic)
https://linustechtips.com/topic/50240-mouse-help/#findComment-670062
How about a CM Storm Sentinal Advance II. Its pretty good for large hands, or the CM Storm Inferno if you need more buttons on your mouse :)!
CPU: AMD FX 8120 @4.5Ghz - CPU cooler: Cooler Master Nepton 240M Watercooling - Mobo: Asus M5A97Pro - GPU: Sapphire Radeon R9 280X Vapor-X @ 1200Mhz - Memory: Kingston Hyper X 16GBs DDR3 - Storage: Kingston SSD & Seagate Baracude HDD - PSU: Cooler Master V850W PSU- Case: Cooler Master Cosmost II
-- Build Log old PC (HAF XB): 'the Cube': http://linustechtips.com/main/topic/36288-the-cube-cooler-master-haf-xb/ --
https://linustechtips.com/topic/50240-mouse-help/#findComment-672791
I will have to look into those mice thanks for the reply!
Does anyone have an opinion on the Steelseries Sensei Raw?
https://linustechtips.com/topic/50240-mouse-help/#findComment-673546
Xh9PSQu.jpg?1
Thanks for the image, I know there are many people that only like optical sensors. I myself have been using a deathadder for some time (new mouse is to be used with a Asus g750 when I travel). But my question is will I actually be able to tell the difference with the acceleration. Like in game would I realize the negative affects of it or is it minuscule enough to not be an issue?
https://linustechtips.com/topic/50240-mouse-help/#findComment-674342
From my experience, you can't notice it when you try to find the difference. But, It does really make a difference. If you play fps, that is. I think it's less important for non-fps games.
https://linustechtips.com/topic/50240-mouse-help/#findComment-674522
Do you think the new deathadder would be a good choice for me? My current one fits good with a claw/hybrid grip. I used to always think the new deathadder was too expensive but I found a good deal on it for $69.99.
https://linustechtips.com/topic/50240-mouse-help/#findComment-674699
Xh9PSQu.jpg?1
Thank you for your opinion, but I find that having lots of extra buttons on a mouse is better. I Can reprogram keystrokes to my muse, and have macros. I'm currently using the Logitech G700, and I love it. I'm planning on buying a Corsair M95 soon. Also, I've never even herd of Zowie. Like at all...... But its in the god tierand demigod tier. Ok then....
https://linustechtips.com/topic/50240-mouse-help/#findComment-674749
Xh9PSQu.jpg?1
well. have you ever seen a filco in a store? Eventho it is the best quality kb imo(actualli ibm model m is #1). The sensors are flawless, that is the main reason why those mice are good
I'd say buy it. Unless you really dont want to spend much money on it. The new one feels really good.
https://linustechtips.com/topic/50240-mouse-help/#findComment-674816
Your welcome, what is your thought on em?
Steelseries Sensie only thing I know its very ergonomic design ... :)
https://linustechtips.com/topic/50240-mouse-help/#findComment-677557
have had 2 rat 7's, absolute crap dont bother
https://linustechtips.com/topic/50240-mouse-help/#findComment-678182
I had one R.A.T. 9 for two years no complaints just suddenly dying after two years. I say take R.A.T. 9 or wired option of that.
Now I have Razer Ouroboros and I say avoid this mouse as much you can it was bad buy but expensive so I will use it out, but I will say to anyone to avoid it.
https://linustechtips.com/topic/50240-mouse-help/#findComment-695532
While I think that poster/chart/graph looks clever and all, I don't quite agree with it. Yes, it seems optical is preferred these days, but I've been gaming with laser mice for years and have no issue playing FPS with them....and when I miss a target, I put it down to my skill, or lack thereof, rather than the sensor on my mice,  I have two mice on that allegedly 'shit' list, a first gen G9 and a Kone XTD, great gaming mice.....and I make this statement w/o any reservations, great mice indeed!
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/50240-mouse-help/#findComment-695979
