Data transfere help
Solved by Captain_WD,
~snip~
Hey there NeonJam
You can use the tool from the SSD manufacturer that comes with it to clone the data from your HDD to the SSD and thus save everything as it is. Have in mind that cloning a HDD to the SSD is not recommended as it has potential problems such as the SSD being recognized as a HDD.
I would recommend doing a fresh install of the OS on the SSD alongside with all the applications and ames that would really benefit from the drive's speed and leave and reinstall everything else on the HDD. Have in mind that gaming relies on the storage's performance only for the loading times and autosave while FPS and graphics stay unaffected.
Captain_WD.
