Received my MasterCase Pro 5 today, when i was unpacking it i noticed that the back side panel wobbles or just doesnt seem to secure all the way even tho its fully screwed in, so i was wondering if anyone here with the same case noticed this, if its a defect on mine or just how the case is.
Made a small quick crappy quality video showing what i mean :)
Ryzen 7 3700x, MSI B450 Tomahawk MAX, 16GB Ballistix Elite 3600MHz, MSI RTX 2070 Super Gaming X Trio, Corsair RM750x V2
https://linustechtips.com/topic/499037-mastercase-pro-5-side-panel-wobbling/
It might not be on properly. If it is a fault with the case, does it really matter? as long as it doesn't affect the aesthetics or functionality of the case. If you're really going to be that picky, just put something thin and soft to reduce the rattle, I know it's not ideal, but noones going to notice or care.
Δ Ambassador for the Illuminati Δ
Δ "Illuminati confirmed" - Nobody  Δ
Wouldnt say im being picky, just asking a question, if the side of the case rattles when components gets installed that would be kind of an issue.
And yes you are also right, putting a bit of padding between the panel and the frame removes it, guess thats gonna be the solution to the problem. Just seems like im rather unlucky when it comes to CM items.
just see how it goes mate
Yep will do ;) Atleast i can be happy about the fact that i got the case for 110$ vs the normal price.
