WileyFox Phone Help
Go to solution Solved by exercutor5,
Hey, So my mum is looking to get this phone (http://www.amazon.co.uk/gp/product/B014UUQUAO?ref_=gbps_tit_s-3_0747_a547625b&smid=A3P5ROKL5A1OLE) So I was wondering, Is  Cyanogen OS just like android with a mod so it would be able to use the Google play store just like here current phone the Moto E. The Specs don't look bad, and its Amazons deal of the day. Would you recommend?
Thanks
CyanogenMod is an Android build based on stock Android with a little bit of extra features built-in here and there. Anything sold by any phone company that comes with CyanogenMod will definitely have the Google Play Store, so no extra tinkering is needed on the user's side.
Thanks
Something Awesome!
https://linustechtips.com/topic/498929-wileyfox-phone-help/
Thanks
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
https://linustechtips.com/topic/498929-wileyfox-phone-help/#findComment-6670491
Thanks very much for the clarification.
Something Awesome!
https://linustechtips.com/topic/498929-wileyfox-phone-help/#findComment-6671005
