Hi,
First of all I am new to the forums but have been following this youtube channel for a bit now.
I just recently purchased a new Inno3D GTX 960 Herculez X2 2GB and I've noticed that the temps are a bit high. It usually gets to around 75C @ 92% fan speed at stock clocks. Is this normal? I saw some people saying that theirs are at around 65-70C. I even made my own custom fan curve to no avail.
Would really appreciate any input in regards to this one. Thanks!
"Dreams worth more than money."
https://linustechtips.com/topic/498752-question-gtx-960-temperature/
That cooler is not the greatest,however,those temps seem a bit high for a 960.Can you repaste the card? I remember reading a post in a forum about the 970 version from Inno,and changing the thermal paste solved the problem
He recently purchased that card, i don't think he should go for repaste that quick
Ryzen 5 3600 | MSI B450 Tomahawk Max | Corsair Vengeance lpx 32gb 3600mhz | EVGA GeForce RTX 3080 FTW3 ULTRA GAMING | XPG Core Reactor 850w
Whats your Room temperature and what about the Case airflow?
Room temp is roughly around 35C or lesser, case airflow seems good as far as I can see, no wires randomly hanging around with 2 intake + 2 exhaust
that fan curve is the only thing that goes to 90% at 72C.. your card is running at 34C and idling in the afterburner screencap..
Are you saying that the fan curve I made is bad? Yeah it's on idle when I took the screencap, but you can see the max outputs there though.
Hmmm.. I just got it though, a bit hesitant that I may void the warranty, I never really checked if the pcb and hsf are properly aligned.
Edit: Also my cpu is air-cooled if that makes any difference.
bugger it i've gone blind
it's a bad paste application, BUT, you should just send the card back, get a refund and go for a 380. Better card, just avoid asus
It may look like it, since I've tried checking around the internet and saw that a fair bit of people have this same issue and a repaste solved it. I'll take it out and give it a quick look tomorrow and decide from there though.
