Graphics card will not overclock
Go to solution Solved by Ostwind,
silly question but it needs to be asked, did you actually apply the settings?
Ok so i need help in figuring out why my titan X will not over clock. I have tried using MSI afterburner and EVGA option. I try to dial up the clock speed but it will not go past the stock speed during benchmarks. The temp of the card does not even go above 50 C so its not a thermal issue. Thanks ahead time for any help with this.
System Specs - windows 7 64
i7 4790K 4GHz
Corsair h100
16 gig corsair vengeance memory
Titan X - EVGA AIO
asus Z-97M-plus
Corsair HX 750 ps
https://linustechtips.com/topic/498458-graphics-card-will-not-overclock/
lol yes i did
What benches are you using and by how much are you changing the clock?
you should also follow this topic and any others you make so you get updated when people post on it.
"The of and to a in is I that it for you was with on as have but be they"
iv been using the msi kombuster and furmark
Try this instead http://www.techpowerup.com/downloads/2208/unigine-valley-benchmark-1-0/ and see what happens when you try to overclock
you know what now i really feel like a tard for some reason it is working right now even though it hasnt for a couple of days of me messing with it. Was setting up to take a screen shot. so i now i feel dumb for creating this post lol. should i mark as fixed of just delete it?
