Are you running it at 144Hz? How does it compare to other displays in regards to strain?
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/498361-vg248-problem/#findComment-6660166
Hey, i recently just got a vg248 yesterday and its really straining my eyes, people say its cause of flicker or something. I have a r9 390 card, Can anyone help?
Im not really sure, just spit balling here. It might be because your eyes are not used to the new format of display. I remember when i upgraded my monitor after 4 years of use of the previous one, my eyes would get tired really fast, but then i got used to it.
https://linustechtips.com/topic/498361-vg248-problem/#findComment-6660169
may wanna turn on v-sync????
also it may be just the transition of either IPS to TN or 60 to 144 hz
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/498361-vg248-problem/#findComment-6660176
Nah 60hz, and not sure i've only ever had one other monitor and i dunno what monitor it is lol got it a long time ago when i bought my first desktop, never had strains with it tho.
https://linustechtips.com/topic/498361-vg248-problem/#findComment-6660177
The higher the refresh rate, the less strain the backlight puts on your eyes. Try running it at 144Hz.
https://linustechtips.com/topic/498361-vg248-problem/#findComment-6660207
Ima need a display port then :) I only have a hdmi
Do you have dual link DVI?
https://linustechtips.com/topic/498361-vg248-problem/#findComment-6660228
