2 way SLI titans
Go to solution Solved by _ASSASSIN_,
depends on how quickly they come out and even then they may not have the same amount of memory. even so i will still need these fittings and i can't find them
this is what you should do, get normal compression fittings for your graphics cards, and then use Bitspower Crystal Link in-between, probably your best and cleanest option imo
http://www.frozencpu.com/products/10744/ex-tub-669/Bitspower_SLI_Crossfire_Crystal_Link_Tube_Set_-_2_Slot_Spacing_BP-CLTAC-S2.html
ok so i have seen linus's overkill pc guide and i am going to build something similar and i wanted to know if anyone knows the name and size of the fittings he used between the GPU's i am going to be using the same koolance blocks as seen in the vid. thanks
  • CPU i7 4790k 4589.16MHz, Motherboard Asus Z97 Deluxe USB 3.1, RAM Corsair dominator platinum 16 gb 3977.3 MHz, GPU Nvidia 3080, Case Corsair 750d, Storage Samsung 850 pro 512gb, WD black 2tb, PSU Corsair HX1000i, Cooling Corsair H110i, Keyboard Corsair k95 RGB, Mouse Logitech G502 RGB, Monitor S2721DGFA, Sound Bose surround system, Operating system Windows 10
https://linustechtips.com/topic/49823-2-way-sli-titans/
Why would you use the fittings he used? He just used ones he had around. You should really be using right angle fittings.
Look at Monsoon/Bitspower fittings if you want good looking fittings at a premium. EK fittings if you want good fittings for a good price.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/49823-2-way-sli-titans/#findComment-663940
i think i need the extra memory as i have 3 1440 monitors and intend to upgrade those soon to 1600. i dont think the 780's will cut it
https://linustechtips.com/topic/49823-2-way-sli-titans/#findComment-663948
He uses 3/8 ID and 5/8 OD Compression fittings
this is for the rest of the build. for the GPU's he uses specialist fittings to mount them side by side as the gap is very small for tubing to be used.
watch this at 16:00 http://www.youtube.com/watch?v=JtHDqdo5pR0&feature=c4-overview-vl&list=PL8mG-RkN2uTwlcLU_rv29Gt4578XfgJm_
https://linustechtips.com/topic/49823-2-way-sli-titans/#findComment-663969
They are still 3/8 ID 5/8 OD Compression fittings...
https://linustechtips.com/topic/49823-2-way-sli-titans/#findComment-663985
https://linustechtips.com/topic/49823-2-way-sli-titans/#findComment-664025
thanks this looks similar and should work.
https://linustechtips.com/topic/49823-2-way-sli-titans/#findComment-664043
