around $80 and decent... he is running on a laptop and he has some usb "sound card" thing
He's going to need a full out desktop to take advantage of any sound card.
"Not breaking it or making it worse is key."
"Bad choices make good stories."
https://linustechtips.com/topic/497309-sound-cards-help/#findComment-6648031
For PCIe, a Sound Blaster Z-series card will work. If you want to treat him to a little bit more by paying up a little bit more, then you can get an Asus Xonar sound card.
https://linustechtips.com/topic/497309-sound-cards-help/#findComment-6648065
The general go-to for cheap sound cards tends to be the base Sound Blaster Z.
I'd have to ask though, since cheap is what you mentioned, what speakers or headset/headphones is he running? And also what motherboard is in the desktop so that we can assess the onboard capabilities in comparison with adding a sound card.
MSI Z97M Gaming | i7-4790k | NZXT Kraken X61 | 16GB Kingston Savage DDR3 2400
EVGA GTX1080 Ti FTW3 | EVGA G2 750 | Phanteks Enthoo Evolv | 1TB 850 Evo | 2TB 860 Evo | 22TB DS918+
Scarlett 2i2 | WooAudio WA7 Fireflies | Fostex TR-X00 | Beyer DT990 | MrSpeaker Alpha Dog | V-Moda M-100 | JBL LSR305 MK2
https://linustechtips.com/topic/497309-sound-cards-help/#findComment-6648188
I have a Xonar DGX that I got for about $35 that I really like, especially after I replaced the stock driver with the Xonar UNI driver.  It has a built in headphone amp that actually works.  There is no noticeable improvement in sound quality on headphones that are easy to drive however.  That's not a bad thing, it's just it is really hard to notice an improvement over good onboard sound.
Depending on what it is you probably won't be able to do better than that USB sound card thing he already has for that budget.  It's usually better to have an external DAC anyway because it's away from the internal computer noise that can cause interference.
For specific recommendations, this isn't within the budget you set but if I upgrade it's going to be the ODAC+O2 amp/DAC, or maybe the ODAC with a different amp, or maybe the Schiit stack.
https://linustechtips.com/topic/497309-sound-cards-help/#findComment-6649079
