Hey guys
I will start op with sorry for bad english i hope you understand and will help.
i am building a pc.
i brought some stuff on sale black friday, including core i 5 4690k 35%off, corsair cx600m 50% off and 16gb hyperx 1666mhz ram 30% off
i now have
i5 4690k
psu cx 600m
16gb ram
case: define R5
windows
850 evo ssd
2 tb harddrive
motherboard proberly msi z97 gaming 5 not brought yet
i need help, i can´t decide which gpu i shall buy
i am a looking at thees
gtx 970, 960 4gb
R9 380, 380x 390
what do you guys think is the best option for me with the spec of my pc?
help would be great
thanks in Advance
greeting mads
https://linustechtips.com/topic/496133-gpu-for-first-build/
Hey guys
i am building a pc.
i now have
i5 4690k
psu cx 600m
16gb ram
case: define R5
windows
850 evo ssd
2 tb harddrive
gtx 970, 960 4gb
R9 380, 380x 390
help would be great
thanks in Advance
greeting mads
First off change the PSU! Look at the EVGA supernova g2
Secondly go for the best gpu you can afford! so either 390 or 970
If you want a reply PLEASE QUOTE ME!
WE NEED CUSTOM MEMBER TITLES AGAIN!!!!!
Member title post link!
https://linustechtips.com/topic/496133-gpu-for-first-build/#findComment-6635890
is it that bad ? 3 of my real life friends have it with no problems, one of them have an 970 and i7 4790 cpu
https://linustechtips.com/topic/496133-gpu-for-first-build/#findComment-6635894
snip
This just had to be posted...
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/496133-gpu-for-first-build/#findComment-6635924
do you know a psu for 40-60 bucks that is better? aswell as what about gpu only one has answered the real question what gpu :)
If your budget stretches to a 980 then get one otherwise the 390 or 970, both are good (some say 390 is better) but up to personal red vs green prefrence
https://linustechtips.com/topic/496133-gpu-for-first-build/#findComment-6637562
https://linustechtips.com/topic/496133-gpu-for-first-build/#findComment-6637569
