No POST and peripherals not lighting up
Solved by Drogoth,
Hi, I've been using my new PC for about three weeks now and had no problems, I took of the front fascia to clean my dust filter but then when I went to turn it back on I got no post and none of my peripherals were lighting up.
My specs are:
Corsair spec 01
Corsair CX750M
i5 4690K
Asus H81-Gamer
212 EVO
16gb kingston hyperx fury
Everything was fine until I took off the front fascia.
Please help.
Thanks
Stupid question but is your PSU correctly plugged and is it switched ON ?
Also, check your front pannel connectors to your motherboard if you're trying to power your system up using your case's power button ![]()
