you should be able to change the keyboard layout and language within windows. but i would suggest getting the properly formatted keyboard if greek is not similar to the english layout.
Please Quote so i know you have replied. | If we have provided a solution to your problem mark it with answer found.
And also please read the COC and avoid the embarrassment and lecture that will ensue.
https://linustechtips.com/topic/495168-help-with-keyboard/#findComment-6625873
