So this issue has been happening for some time, and I’m finally getting sick of it
What happens is; When I’m playing a game (happens on every game i play) in this case it was fallout 4, game will be running fine all of a sudden my computer freezes (time before freezes can't be made due to the fact it is seemingly random sometimes i can run it for hours other time less then 20min before it freezes) sometimes you can hear a sharp ripping noise from the audio when it freezes, and my power reset switch no longer works so i have to hold power button for around 5-15 seconds.
So I ran
HDTune; No Errors
Memtest (windows); No Errors
Furmark; Nothing unusual
Loaded Asus optimized defaults; still freezes after doing this
SPECS:
Mobo; Asus Z170M PLUS
CPU: Core i5 6500
GPU: Gigabyte GTX 970 (GV-N970WF3OC-4GD)
Memory; 16GB corsair vengeance lpx DDR4 at 2400MHZ (2x8GB)
PSU: Corsair VS550
OS: Win 10 64-Bit
Anyone know a solution to this? or has experianced this before?
https://linustechtips.com/topic/494160-pc-keep-freezing-randomly/
So I ran
HDTune; No Errors
SPECS:
CPU: Core i5 6500
PSU: Corsair VS550
OS: Win 10 64-Bit
Have you tried running just one stick of ram? Seems like a weird bug, could be software related but I'm just taking a stab in the dark
If you have the option to get a high refresh rate monitor, do it.
Main PC CPU: i7 14700k CPU Cooler: NZXT x62 280mm Motherboard: Gigabyte Aorus Elite X WiFi 7 GPU: Asus Strix 3080ti RAM: Gskill Trident Z5 32gb DDR5 SSD: 990 Pro 2TB, 980 Pro 1TB Case: NZXT S340 Black PSU: Corsair RM1000e ATX3.0
Server: CPU: i7 9700k RAM: Corsair 32gb DDR4 HDD: 36tb Usable SSD: Samsung 500gb NVME Case: Fractal Define R5 PSU: Corsair RM1000e ATX3.0
Running one stick seems to be fine, so i assume the other stick is either faulty or unstable?
have you tried running the other stick on it's own? or trying out different configurations of them
