Ok so I have been looking at parts to build my own Computer. Now I just need someone to tell me if the parts that I have selected are right and appropriate. I had about a $500 budget. I selected a Black and White theme.
Case: DIYPC Shadow-H01-W MB: MSI Computer ATX DDR31066 NA 970A SLI Krait Edition
GPU: EVGA GeForce GTX 950 2GB FTW GAMING
CPU: AMD FX-6300 6-Core Processor Black Edition
RAM: Kingston HyperX FURY 8GB Kit (2x4GB) 1866MHz DDR3 CL10 DIMM / White
HD: Western Digital Caviar Black 1 TB SATA III 7200 RPM 64 MB
Power: EVGA 500 W1 80+
So if you have any recommendations please tell me, thank you.
https://linustechtips.com/topic/493969-recommendations-for-build/
Where do you live?  What are you using this PC for?
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
Assuming you live in the US and you're gaming with this, this will perform much better than the one you drafted.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($159.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H81M-H Micro ATX LGA1150 Motherboard  ($39.99 @ Newegg)
Memory: Team Dark 8GB (1 x 8GB) DDR3-1600 Memory  ($28.99 @ Newegg)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  ($179.99 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($33.15 @ SuperBiiz)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($45.90 @ SuperBiiz)
Total: $527.11
Generated by PCPartPicker 2015-11-27 15:39 EST-0500
Total: $527.11
Thanks for the help
