Hello there Im pretty bad at pc tech stuff soo im asking you guys for your help..Im looking for an upgrade on my pc i dunno what i need to upgrade to make it better..
Suggest anything
Pc specs:
Processor AMD Athlon X4 760K Quad Core Processor Video Card NVIDIA GeForce GTX 650 Memory 8.2 GB
  And my motherboard is asus(dont know anything else about my pc  :D)
https://linustechtips.com/topic/492820-need-help-upgrading-my-pc/
Budget and Location?
CPU:Intel Core i3 3210 Mobo:MSI B75MA-E33  GPU:Intel 2500 HD Graphics  SSD:Adata SP600 128gb  HDD:Seagate 1tb 7200rpm
PSU:Corsair CX430   Case:Antec ASK4000bU3  Monitor:Dell S2240l 21.5 inch 1080p
well.. i hate to be that person.
but if you are uncapable of popping off the side of your pc and search for model numbers by yourself, i'd suggest you dont do upgrades yourself...
Hard drive? SSD if you have't already got one goes without saying really...
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 4TB Crucial P3 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 11 Pro x64
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  (€163.00 @ Amazon Espana)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  (€95.00 @ Amazon Espana)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  (€79.95 @ Amazon Espana)
Video Card: XFX Radeon R9 390 8GB Double Dissipation Video Card  (€402.89 @ Amazon Espana)
Case: Corsair SPEC-02 ATX Mid Tower Case  (€69.83 @ Amazon Espana)
Total: €989.43
Generated by PCPartPicker 2015-11-26 13:37 CET+0100
Use your 8gb memory stick(s)
Total: €989.43
well then i said bugget isnt a matter i didnt mean to be like 1k€ i would like to be as cheap as possible..Sorry for misleading consept
Get a 120 gig ssd.
 Well maybe you are right sir..but im trying to get all the model numbers atm
Ok then, just tell us what games do you want to play and if you want to be able to upgrade later on and we will try to make you cheap PC
CPU: Ryzen 5 2600, MOBO: MSI Tomahawk B450, RAM: Corsair Vengeance RGB 3000 (2x8 GB), GPU: MSI RTX 2080 Gaming-X Trio, CPU Cooler: Noctua NH-U12S, PSU: Corsair RM 650, HDD: WD Blue 1TB, SSD: Samsung 860 ECO 500GB, CASE: Fractal Design Meshify C
I want to play ac unity/fallout 4 smoothly..I mostly play online games like csgo league of legends etc. And yes i will want to upgrade even more later on
RAM: HyperX Fury (2 x 4 GB) 2133 MHz DDR4
MOBO: Asus H170-PRO
GPU: ASUS STRIX-R9380
CASE: Corsair Carbide Series SPEC-03
PSU: EVGA 650 W G2 GOLD 80+
CPU: Intel Core i3 6100
HDD:  WD BLUE 1TB
_________________
Total:
 £623
P.S. Storage is personal, so don't feel like you need the WD Blue, you can get GTX 960 if you want NVIDIA over AMD - that's also personal.
If you don't like this option you can see in Google for PC builds that can beat the PS4 and XBOX One
