Hi ive been using chrome for 3 years its been a great browser but lately it became hella slow my pc dont have anything wrong but the browser is relly slow can you help me plz
You can try uninstalling and reinstalling it. It seems to be buggy lately as i have been having some issues as well with it,.
What windows version are you running?
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
https://linustechtips.com/topic/492091-help-with-chrome/#findComment-6596864
Windows 10
Did you upgrade or clean install windows 10. Weird issues have been floating around with the upgrade.
https://linustechtips.com/topic/492091-help-with-chrome/#findComment-6596908
Upgraded when i had windwos 7 i had no problems and with windows 10 i have no problems too everything is ok only chrome is acting weird
Ok try uninstalling Chrome completely (may want to run a cleaner after the uninstall) then reinstall it and see what happens.
https://linustechtips.com/topic/492091-help-with-chrome/#findComment-6596935
