Hard Drive Partitioning
Go to solution Solved by bloader,
So my Toshiba 3TB drive arrived today, I transferred all of my data from my Seagate 1TB to the new drive successfully. Weirdly, about 750GB of the space of the hard drive is completely unusable. It's showing as unallocated in Disk Management, and when I try to create a simple volume, the options are greyed out. The largest partition I could make was exactly 2TiB.
Anybody know what might be going on?
it has to be set up as GPT for it to use more than 2tb
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/491638-hard-drive-partitioning/
Gigabyte X570 UD
Ryzen 5 5600x
16GB 3200mhz ram
Asus TUF Rx5700XT
600w PSU
256GB NVME boot drive
1tb sata ssd game drive
2tb mechanical storage drive
Logitech G815 Tactile
Logitech G502
AudioTechnica ATH-G1WL
LG B9 OLED
https://linustechtips.com/topic/491638-hard-drive-partitioning/#findComment-6591434
I had just found out, thank you. :)
Incipere V5.0
Parvulus V1.0
https://linustechtips.com/topic/491638-hard-drive-partitioning/#findComment-6591469
