Hello,
I have the following issue with my new sistem.
When I press the power button on my case, the sistem start up, run POST, then it shut down by itself. If I press the power button again, it's starting up and everything run like normal. This happens every single time. do you have any ideeas?
I3 6100 3.7 GHz
Asus H110M-A
Asus GTX 750 Ti PH 2GB DDR5 128Bit
Crucial DDR 4 8GB 2133MHz Dual Channel
HDD 7200 RPM 500GB
PSU FSP HEXA+ 400
https://linustechtips.com/topic/491465-sistem-shut-down-after-post/
Hello,
I3 6100 3.7 GHz
Asus H110M-A
HDD 7200 RPM 500GB
PSU FSP HEXA+ 400
Clear CMOS first and see if that solves the issue. And are you getting any error beeps, codes, or anything on screen?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
@iCobie  I've tried with one stick RAM, same issue on both ports and RAM sticks
@BlueChinchillaEatingDorito There is no beep, no error, nothing
@Geospan1 I've tried with onboard graphics card, same issue. All parts were bought last week, the only thing that I oldish in the HHD, 4-5 months since I bought that.
Was the system ever operational?
What I don't understand is why after it shuts down, if I start it again, every thing works normal..... :angry:  Basically, the system is working after 2 start ups :lol:
I had the same problem once because I had like 5 devices to the same wall plug (which is a no no)
