Hey Guys,
So I recently upgraded my pc to the following specs. http://au.pcpartpicker.com/p/dLb4zy, anytime from 15 mins to a few hours in my system freezes with the current activity still on the screen. Any idea what it could be. I'm running 2x 1080p monitors.
It doesn't seem to be related to the temps as I have been monitoring them and I can push the GPU to 80c and no crash and then open a web browser and then it crashes. at 30-50c same goes for the CPU doesn't peak much at all with the Corsair H110iGTX AIO
I'm running a fresh install of windows 10 on a SSD.
Any help would be appreciated.
Cheers
*EDIT*
I have also been watching power draw and output and it doesn't go over 550w. So I don't think its power related.
https://linustechtips.com/topic/491331-pc-freezing-issues/
hmm hard to  tell. try to change some part if you have any spare parts.
try changing the GPU with the older one and see if it make any difference, and if you have another CPU with the same socket try that t oo
you see this? this is my signature. btw im Norwegian
CPU - Intel I7-5820K, Motherboard - ASUS X99-A, RAM - Crucial DDR4 Ballistix Sport 16GB, GPU - MSI Geforce GTX 970, Case - Cooler Master HAF XB evo, Storage - Intel SSD 330 Series 120GB - OS, WD Desktop Blue 500GB - storage 1, Seagate Barracuda 2TB - storage 2, PSU - Corsair RM850x (overkill i know), Display(s)- AOC 24" g2460Pg, Cooling - Cooler Master Hyper 212 Evo, 2 Noctua 120mm PWM, 1 Corsair 120mm AF RED LED, Keyboard - SpeedLink VIRTUIS Advanced, Mouse - razer deathadder chroma, Sound - Logitech Z313, SteelSeries Siberia V2 HyperX Edition, OS - Windows 10 (prefer windows 7)
https://linustechtips.com/topic/491331-pc-freezing-issues/#findComment-6587225
Are you trolling? That build looks like an eleven year old chose the parts...
"More GHz! More cores! More VRAM! CrossFire sounds cool!"
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/491331-pc-freezing-issues/#findComment-6587236
Have you tested what the CPU temperatures are?
I suggest you download temp monitor such as speccy...
I bet your freezing issue is temperature related.
My Rig: - Gigabyte Z97 X5 MB / Core i7 4790K @ 4.4Ghz - Water Cooled Coolmaster AIO Loop (Push - Pull Config)/ 8GB Corsair Dominator ram at 2400Mhz / Palit Jetsteam GTX 980 OC edition / 128GB SSD OS / Program Drive + 2 TB hard drive storage / Win 10
https://linustechtips.com/topic/491331-pc-freezing-issues/#findComment-6587562
