Here is the link to sysnativefilecollection. https://drive.google.com/file/d/0B0On5eKk-2lvWXcwUnVyZExFdW8/view?usp=sharing
Here is the link to the Preform file. https://drive.google.com/file/d/0B0On5eKk-2lvWC10OVQ1bjQxQ1E/view?usp=sharing
I was using sony vegas for video editing then my computer blue screened. This is the 3rd time within a month i am starting to get really concerned. I believe all you need is in those links. Please help me.
https://linustechtips.com/topic/490484-3rd-blue-screen-please-help/
*snip*
Considering video-editing software is a heavily utilizes RAM, I suggest you start there. You will need a flash drive.
Download the Memtest86 auto installer from here and run it, selecting your flash drive. Once complete, shut down your machine, and boot off the flash drive.
Use it to test your RAM and see if you have a defective stick (or more).
Let us know if the test successfully completes, or if it returns any errors.
CPU- i5 4670K CPU Cooler- Corsair H90 MB- MSI Z87 GD-45 RAM- 16gb G.Skill Ripjaws Case- NZXT Phantom 530
PSU- Corsair CX750M Cooler- Corsair H90 Boot Drive- Samsung 850 Evo 250GB
Storage-WD 1TB Blue Storage- Seagate 2TB
I do not have any flashdrives. Also i have crashed while playing the game rust my other 2 times.
It just crashed again. I was watching a youtube video. wtf is happening
If it's ram sometimes just swapping dim slots can help.  Watching youtube shouldn't be putting much load on your system so I'd start by trying that, maybe removing a stick at a time and seeing if you can get stability.  BTW I think windows has a memory tester built in now?  Is it any good?
I could not get it to boot from the usb
i did ur test and there were no errors
Assuming the test is correct I suggest checking your system files. Open an elevated command prompt and type the command "sfc /scannow" without quotes.
It will search for missing or corrupted Windows files and replace them.
i did that it said everything was fine
