Monitors Refuse To Work!
Go to solution Solved by Carlospicyness,
Installing the newest drivers did the trick.
I have four monitors and currently only one is working. I have narrowed the problem down to the graphics card as the monitors worked well with the 260X I was using. I just went back to my old 280X and now it just refuses to show more than one monitor. I would be happy to provide anymore information if it helps.
https://linustechtips.com/topic/490344-monitors-refuse-to-work/
Are the monitor being detected?
No? Not detecting the other monitor? Which port is the working port? Use a converter to see if the other ports are working.
If death has no cost, life has no worth
The dead are gone, the living are hungry
Life is not about finding yourself, it's about creating yourself.
https://linustechtips.com/topic/490344-monitors-refuse-to-work/#findComment-6576497
It detects the two on either side of the center monitor, but claims they are disabled. In device manager they are enabled. The top monitor states that there is an incorrect resolution and disconnects the center monitor when plugged in. The far left monitor is connected by DVI to DVI. As is the far right monitor. The center monitor is connected DVI to HDMI. The top monitor is connected VGA to Displayport. The far left, top, and far right monitors are all 1280X1024 and the center is 1920X1080.
https://linustechtips.com/topic/490344-monitors-refuse-to-work/#findComment-6576690
  • 4 weeks later...
