Hello,
I just upgraded my PC from my old specs (in my signiture) and i want to upgrade it to Windows 10 from 7, but i dont know if i should?
 - I run the entire Adobe CC suite
 - Games and what not
Second question,
1tb M.2 SSD or 1tb SSD for a HDD replacement
Cpu: 5820K @4.0GHz   Motherboard: Gigabyte X99-SLI    Ram: Patriot Signature 16GB @ 2133   GPU: Gigabyte G1 980  Soundcard: ASUS DX
 Speakers: Logitech Z906 and Astro A40's   Keyboard: Logitech G510
https://linustechtips.com/topic/489900-two-part-question/
I would, Windows 10 is awesome and I have encountered no bugs thus far :)
and 1TB SSD, it's really not worth the extra money for M.2 imo
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/489900-two-part-question/#findComment-6571325
Don't use win10. And as for the rig, just a GPU upgrade will be fine.
I've already upgraded my rig. to a 5820k and a 980 with 32gb ram.
I just wanted to know if a 1tb ssd is worth it or is a HDD still good?
https://linustechtips.com/topic/489900-two-part-question/#findComment-6571387
you will see a slight improvement in games , but windows 10 is kind of buggy for me.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/489900-two-part-question/#findComment-6571460
windows 10  has been buggy for me, but dx 12 is win10 only , so for games that will help (for those that use it)
I would upgrade anyway, that way you won't have to pay for it in tyhe future , just disable the privacy invading options in the settings.
https://linustechtips.com/topic/489900-two-part-question/#findComment-6571470
