I want to buy a PC (buy the hardware and build it myself) at about the price of 800 euros. The PC i want to buy/build will be exlcusively for gaming purpuses only (1080p gaming). Note that i would prefer it to be able to play games that will be released the next 3-4 or so years decently. The only parts i won't need to buy are the mouse, keyboard  the OS and the storage unit (HDD / SSD). This means i will need to buy a new monitor. Please give me your suggestions because i don't have any experience of understanging what performance a given system will have exactly. Thanks in advance :)
https://linustechtips.com/topic/489535-help-buying-a-pc/
Do you have a set price range or is it all or nothing?
Intel Core i7-6700K | EK-XLC Predator 360 | Gigabyte GA-Z170XP-SLI | Corsair Vengeance LPX 32GB | Intel 600p Series 256Gb M.2 280 | PNY GTX 1070 XLR8 | NZXT H440 Black/Red| LG29UM68-P | Corsair RMx 750W 80+ Gold |
Gotta Go Fast       - Barrack Obama 2015
https://linustechtips.com/topic/489535-help-buying-a-pc/#findComment-6567564
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  (£133.90 @ Amazon UK)
Motherboard: MSI Z97-Gaming 3 ATX LGA1150 Motherboard  (£92.99 @ Ebuyer)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  (£41.41 @ CCL Computers)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  (£85.90 @ Amazon UK)
Monitor: Asus VS228HR 60Hz 21.5" Monitor  (£92.95 @ Amazon UK)
Total: £801.10
Generated by PCPartPicker 2015-11-21 22:26 GMT+0000
https://linustechtips.com/topic/489535-help-buying-a-pc/#findComment-6567576
 Ignore mine :3 Get the list above. But so you can have choices..
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  (€211.68 @ Mindfactory)
Motherboard: ASRock H170M-ITX/DL Mini ITX LGA1151 Motherboard  (€102.44 @ Mindfactory)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  (€56.49 @ Amazon Deutschland)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  (€46.89 @ Amazon Deutschland)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (€52.64 @ Mindfactory)
Video Card: XFX Radeon R9 280 3GB Double Dissipation Video Card  (€201.43 @ Amazon Deutschland)
Case: Fractal Design Core 500 Mini ITX Desktop Case  (€62.38 @ Mindfactory)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  (€77.29 @ Mindfactory)
Total: €811.24
Generated by PCPartPicker 2015-11-21 23:27 CET+0100
Moist
https://linustechtips.com/topic/489535-help-buying-a-pc/#findComment-6567583
Video Card: XFX Radeon R9 390X 8GB Double Dissipation Video Card  (£319.96 @ CCL Computers)
Total: £801.10
Euros, not GBP.   ;)
https://linustechtips.com/topic/489535-help-buying-a-pc/#findComment-6567612
Euros, not GBP.   ;)
Whoops, Euros and Pounds look the same to me. :P
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  (€162.04 @ Amazon Deutschland)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory  (€48.48 @ Amazon Deutschland)
Video Card: Gigabyte Radeon R9 390 8GB Video Card  (€334.84 @ Mindfactory)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  (€57.33 @ Mindfactory)
Monitor: Asus VS228HR 60Hz 21.5" Monitor  (€119.00 @ Amazon Deutschland)
Total: €798.98
Generated by PCPartPicker 2015-11-21 23:36 CET+0100
https://linustechtips.com/topic/489535-help-buying-a-pc/#findComment-6567630
Total: €798.98
Seems like its not your day...  :unsure:
Two problems with your build:
  • The motherboard doesn't have pricing in PCPP, which means it is not included in the end price. So it's over his budget.
  • Apart from that the motherboard would've not been a good choice anyways, because the CPU has a locked multiplier. That means he doesn't need the Z97 chipset and would be fine with a H97, H87, H81 or B85 chipset.
https://linustechtips.com/topic/489535-help-buying-a-pc/#findComment-6567685
Here's a build with a new mobo that has a price tag. Hopefully I'll get more sleep tonight.
Motherboard: Gigabyte GA-B85M-D2V Micro ATX LGA1150 Motherboard  (€53.95 @ Amazon Deutschland)
Video Card: Gigabyte Radeon R9 390 8GB Video Card  (€326.85 @ Mindfactory)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  (€77.22 @ Mindfactory)
Monitor: Hannspree HE225DPB 21.5" Monitor  (€103.99 @ Amazon Deutschland)
Total: €829.86
Generated by PCPartPicker 2015-11-22 01:09 CET+0100
https://linustechtips.com/topic/489535-help-buying-a-pc/#findComment-6568269
