airflow optimized fans
Go to solution Solved by nightlitezzz,
Be Quiet! Silent Wings 2
DOUBLE POST
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/48931-airflow-optimized-fans/#findComment-650979
Do you know how these compare to the noctuas NF-S12A?
These will be the same if not slightly quieter than the S12s while providing a butt ton more static pressure to over come filters. The S12As will suffocate for air once they have anything restrictive.
https://linustechtips.com/topic/48931-airflow-optimized-fans/#findComment-654184
Alright that sounds good thanks for the suggestion
hmm
https://linustechtips.com/topic/48931-airflow-optimized-fans/#findComment-654192
