Hi guys,
I'm currently trying to push my gtx 970 a little further but the core clock that I set on afterburner doesn't seem to apply.
At stock, I run at 1291Mhz, I apply an offset of +150Mhz but the core clock is maxed out at 1340ish Mhz.
I don't understand why it doesn't apply the core clock because earlier today, I reached 1500Mhz (but wasn't stable :/ )
Can you help me?
Gaming rig : i5 6600k | EVGA 1070 FTW | 16Go DDR4 HyperX Fury | Intel 600p - WD Black
Laptop : Macbook 2017
Home server : AMD A10 7700k | 2*2TB unraid array + 250GB ssd cache
https://linustechtips.com/topic/489200-problem-with-afterburner/
Hi guys,
Can you help me?
Is the card thermal throttling?
Quote me if you want me to see your message. Like my post if it helped. Click "Show More" to see things that I use.
Desktop (2014): CPU: Intel Core i5 4690k @ 3.50GHz | GPU: MSi GTX 970 Gaming 4G | Motherboard: MSi Z97 Gaming 5 | RAM: 2x4GB G.Skill RipJaws X 1600MHz + 2x4GB HyperX Black 1600MHz | SSD: Samsung 750 Evo 120GB | HDD: WD Black 1TB | Cooler: Cooler Master Hyper 212x | PSU: Corsair VS650 | Case: Cooler Master Elite 431 Plus | OS: Windows 10 Home
Laptop (2017): Model: Asus UX310U
Peripherals: Monitor: Samsung S24D300 OC@75Hz + Viewsonic XG2401 (144Hz) | Mouse: Logitech G305 | Keyboard: Razer Blackwidow Chroma V2 | Headset: HyperX Cloud Core | Speakers: Logitech Z333 | Additional: Logitech G29
Mobiles: Samsung Pixon (2010-2012) | Samsung Galaxy Ace (2012-2013) | Samsung Galaxy S3 (2013-2016) | Samsung Note 4 (2015)(Lost) | Samsung Galaxy S7 (2016-2019) | Samsung Galaxy S10 (2019 - Current) | Additional: ASUS Zenwatch 2 (2016)
https://linustechtips.com/topic/489200-problem-with-afterburner/#findComment-6564294
I don't think so, I've played on it for 2 month with an overclock of 1400Mhz
https://linustechtips.com/topic/489200-problem-with-afterburner/#findComment-6564307
Hi guys,
Can you help me?
Have you set the power limit?
https://linustechtips.com/topic/489200-problem-with-afterburner/#findComment-6564375
Yes, I set it to 110%, prioritising the temperature (91°C, that's the max)
https://linustechtips.com/topic/489200-problem-with-afterburner/#findComment-6564385
Also, I retried with an offset of +200Mhz, and it apply the core clock, but is unstable :/
EDIT : stable during 3 runs of MetroLLBenchmark maxed out @1080p with +180Mhz
https://linustechtips.com/topic/489200-problem-with-afterburner/#findComment-6564389
