So ive been researching in a bit more detail about the 80 plus rating, and i just want to know if this is true
80 is the standard efficiency, if you have a PSU with "80 PLUS PSU" rating you have a PSU with 80%
But when you add a metal to the end of the name, such as "Bronze", "silver", "platinum", etc you just add 80 + the value of the metal
so for example
80 plus gold PSU efficiency would be 80 + 10 = 90%
And
80 plus bronze PSU efficiency would be 80 + 5 = 85%
Please correct me if im wrong
Long live Stalin, he loves you; sing these words, or you know what he’ll do!
https://linustechtips.com/topic/488856-80-plus-rating-system/
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/488856-80-plus-rating-system/#findComment-6560425
https://linustechtips.com/topic/488856-80-plus-rating-system/#findComment-6560471
Thanks, was a little confused because my sources collided with eachother
no they dont
https://linustechtips.com/topic/488856-80-plus-rating-system/#findComment-6560479
no they dont
are you spying on me?
But the false information was told to me from a friend, so i think you have to update your NSA drivers
https://linustechtips.com/topic/488856-80-plus-rating-system/#findComment-6560521
no im not spying on you... i was saying that the two sources dont collide.. the efficiency tables match...
EDIT: ok now i get it... the guy in my profile picture isnt an NSA agent.
Edited by Patrick Bateman
https://linustechtips.com/topic/488856-80-plus-rating-system/#findComment-6560531
I said that my sources collided, and thats why i was confused, not that your sources collided
But NP
also 1000 posts anniversary
https://linustechtips.com/topic/488856-80-plus-rating-system/#findComment-6560545
But NP
congrats.
https://linustechtips.com/topic/488856-80-plus-rating-system/#findComment-6560552
so for example
And
We have a post pinned on the main PSU subforum page about this dawg
It's also in my sig :)
https://linustechtips.com/topic/488856-80-plus-rating-system/#findComment-6560901
