I have a AMD X4 860k and I have been trying to find the max safe temp for it with no luck. It runs a bit hot and I want to make sure that I'm not pushing it to far. Idle temps are in the thirties but when playing games it is in the low to mid fifties. Any idea on the max safe temp?
https://linustechtips.com/topic/488383-max-temp-on-cpu/
Those temps are very safe. Only get worried if it gets above 80 degrees
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/488383-max-temp-on-cpu/#findComment-6554627
What do you use to monitor your temps?
https://linustechtips.com/topic/488383-max-temp-on-cpu/#findComment-6554673
