Power Supply Compatibility
Go to solution Solved by thekeemo,
its a standard form PSU
A GS/g2 550w will be perfect for you
Hello,
I want to upgrade my power supply, but I'm struggling to find out if my PSU is compatible.
Here are my specs:
Motherboard: Acer Aspire ax3960, mini ITX intel h67.
GPU: MSI Radeon r7 250 oc 1GD 5.
CPU: Intel Core i5 (2300)
Case: Thermaltake core V1.
(Ram: 3x 2gb DDR 3)
Storage: WDC WD10EARS-22Y5B1, 1 TB Sata drive, 5400 RPM.
Optical Drive: ATAPI DVD A  DH16ABSH, DVD writer.
I think everything will be compatible, I only don't know if I should look a the voltages etc. I also don't know how haha.
So, will this PSU blow up my motherboard or something?
And is there a slot for my graphics card's power?
Thanks in advance.
https://linustechtips.com/topic/487982-power-supply-compatibility/
