GPU heat sink loose
Go to solution Solved by KieranFretwell,
All in the signature. But EVGA SC ACX cooler. GTX 970
I have the same thing on my ACX 780 ti
Just took apart my GPU to put some new paste on it because of heat issues and now the heat sink that is attached to the plastic fan covers is moving. I didn't notice it before and my other GPU doesn't move. All of the screws seem fine. Is this okay? If youd like to see what I'm talking about just either call me on Google hangout or skype me. Skype is laxplayer551 would be greatly appreciated if I could get some help. Thanks.
CPU: Ryzen 5 5600 Motherboard: MSI B550 Tomahawk RAM: 32Gb DDR4  GPU(s): MSI 6800-XT Case: NZXT H440 Storage: 4x 250gb SSD + 2TB HDD PSU: Corsair RM850x with CableMod Displays: 1 x Asus ROG Swift And 3 x 24" 1080p Cooling: H100i Keyboard: Corsair K70 RGB Mouse: Corsair M65 RGB Sound: AKG 553 Operating System: Windows 10
Current PC:
http://i.imgur.com/ubYSO3f.jpg          http://i.imgur.com/xhpDcqd.jpg
https://linustechtips.com/topic/487569-gpu-heat-sink-loose/
What GPU is it, and what cooler design?
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
https://linustechtips.com/topic/487569-gpu-heat-sink-loose/#findComment-6543863
Current PC:
https://linustechtips.com/topic/487569-gpu-heat-sink-loose/#findComment-6543868
Did you tighten the screws evenly?
Tighten one a bit, then the other, then the other. Then tighten it a bit more and go around, if that makes sense?
https://linustechtips.com/topic/487569-gpu-heat-sink-loose/#findComment-6543902
So it's just an ACX thing? It doesn't do it on my ACX 2.0
Current PC:
https://linustechtips.com/topic/487569-gpu-heat-sink-loose/#findComment-6543906
Yeah. Have to multipost since I'm on mobile. I didn't even take that part off. I just took off the cooler to put new paste on. I was wondering if I broke something.
Current PC:
https://linustechtips.com/topic/487569-gpu-heat-sink-loose/#findComment-6543916
Not sure but i have the exact same thing on mine.
Alright I won't worry about it then. Thanks.
Current PC:
https://linustechtips.com/topic/487569-gpu-heat-sink-loose/#findComment-6543987
Either you put too much thermal paste or you did not tighten the screws enough.
Either way, you voided your warranty.
My warranty is fine lmao. I've already called EVGA about me painting them and they are still covered in warranty.
Current PC:
https://linustechtips.com/topic/487569-gpu-heat-sink-loose/#findComment-6544090
Not on EVGA gpus, unless they actually broke something.
Product condition:
Removal and or Defacing of Serial/Part number sticker(s) on ANY EVGA products WILL void ALL warranties. All products ship from EVGA with a serial sticker.
There must be no physical damage to any component including the PCB, GPU/chipset, CPU Socket, or damage that is caused by:
inadequate or improper repairs carried out by any person or entity which is not authorized by the manufacturer to perform warranty services on its behalf;
negligence, accidents, modifications, defective installation or misuse and use of inappropriate spare parts;
fire, immersion in liquid, lightning, earthquake, inadequate ventilation, Acts of God, incorrect application of main voltage howsoever arising, or any other cause beyond the control of EVGA;
any other goods which can be used with the Product, but are not the Product itself;
consumable or wearing items requiring replacement as part of normal service, including (but not limited to) dry cells and rechargeable batteries.
The product must be returned to EVGA in the original factory configuration and condition. All aftermarket modification must be reversed before sending in the product for replacement.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/487569-gpu-heat-sink-loose/#findComment-6544106
You removed the cooler from the PCB
That automatically voids your warranty, kind sir.
Like everyone else said. Not for EVGA. I even called them.
Current PC:
https://linustechtips.com/topic/487569-gpu-heat-sink-loose/#findComment-6544172
